跳转到主内容
Acer Aspire V5-131-2680 Battery Replacement
你所需要的
  1. Acer Aspire V5-131-2680 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure your laptop is powered down and completely closed before proceeding.
    • Turn your laptop upside down. The stickers should be facing up.
  2. Acer Aspire V5-131-2680 Battery Replacement: 步骤 2 中的图像 1,2 Acer Aspire V5-131-2680 Battery Replacement: 步骤 2 中的图像 2,2
    • To open the bottom compartment, put one finger underneath the laptop and firmly grab the compartment with your thumb.
    • You can also use both thumbs for more pressure.
    • Carefully slide the bottom compartment with your thumb until you feel it pop out of place.
  3. Acer Aspire V5-131-2680 Battery Replacement: 步骤 3 中的图像 1,2 Acer Aspire V5-131-2680 Battery Replacement: 步骤 3 中的图像 2,2
    • In front of the battery, you will find a sliding flap. This is a battery-release lock.
    • Place your finger on the latch and slide the latch to open. Pull out the battery from its compartment.
    • Do not remove your finger from the latch while sliding the battery out.
    • Once the battery is out, release the latch.
结论
Naomi Zaldana
于09/26/22注册
147 声望
撰写一个指南
团队
CSU Los Angeles, Team 6-1, Adachi Fall 2022 CSU Los Angeles, Team 6-1, Adachi Fall 2022 的会员
CSULA-ADACHI-F22S6G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 223
