跳转到主内容
Acer Aspire V5-131-2629 Screen Replacement
你所需要的
  1. Acer Aspire V5-131-2629 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 Screen Replacement: 步骤 2 中的图像 1,1
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 Screen Replacement: 步骤 3 中的图像 1,1
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 Screen Replacement: 步骤 4 中的图像 1,2 Acer Aspire V5-131-2629 Screen Replacement: 步骤 4 中的图像 2,2
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 Screen Replacement, Cover: 步骤 5 中的图像 1,1
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 Screen Replacement: 步骤 6 中的图像 1,2 Acer Aspire V5-131-2629 Screen Replacement: 步骤 6 中的图像 2,2
    • Remove the cover by sliding it outwards and remove it from the device.
  7. Acer Aspire V5-131-2629 Screen Replacement, Screen: 步骤 7 中的图像 1,2 Acer Aspire V5-131-2629 Screen Replacement, Screen: 步骤 7 中的图像 2,2
    • Remove the screen bezel by lifting up the inside rim of the bezel and popping the edge out in steady upwards and outwards motions.
    • Complete this motion around the entire circumference of the bezel.
  8. Acer Aspire V5-131-2629 Screen Replacement: 步骤 8 中的图像 1,3 Acer Aspire V5-131-2629 Screen Replacement: 步骤 8 中的图像 2,3 Acer Aspire V5-131-2629 Screen Replacement: 步骤 8 中的图像 3,3
    • Remove the four Phillips screws from each of the mounting tabs in the corners of the screen.
  9. Acer Aspire V5-131-2629 Screen Replacement: 步骤 9 中的图像 1,1
    • Peel back the adhesive tape that runs the length of the bottom of the screen.
    • Be careful not to damage the cables which run between the tape and the screen.
  10. Acer Aspire V5-131-2629 Screen Replacement: 步骤 10 中的图像 1,1
    • Using the mounting tabs at the top corners of the screen, gently lift the screen up and out and lay it flat on the keyboard.
  11. Acer Aspire V5-131-2629 Screen Replacement: 步骤 11 中的图像 1,1
    • Remove the adhesive tape covering the gold-colored connector on the top left corner of the screen.
结论
Aaron Almeida
于10/25/19注册
551 声望
创作了4篇指南
团队
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 的会员
UMASSD-O'CONNELL-F19S1G3
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 550
