跳转到主内容
Acer Aspire V5-131-2629 Hard Drive Replacement
你所需要的
  1. Acer Aspire V5-131-2629 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 Hard Drive Replacement: 步骤 4 中的图像 1,2 Acer Aspire V5-131-2629 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 Hard Drive Replacement, Cover: 步骤 5 中的图像 1,1
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 Hard Drive Replacement: 步骤 6 中的图像 1,2 Acer Aspire V5-131-2629 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Remove the cover by sliding it outwards and remove it from the device.
  7. Acer Aspire V5-131-2629 Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 1,1
    • Locate the large blue hard drive on the left side on the computer.
  8. Acer Aspire V5-131-2629 Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Gently pull out the ribbon cable on the computer-attached end.
  9. Acer Aspire V5-131-2629 Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Completely remove the hard drive from the hard drive bay.
  10. Acer Aspire V5-131-2629 Hard Drive Replacement: 步骤 10 中的图像 1,2 Acer Aspire V5-131-2629 Hard Drive Replacement: 步骤 10 中的图像 2,2
    • Remove the two screws on the side of the hard drive cage.
  11. Acer Aspire V5-131-2629 Hard Drive Replacement: 步骤 11 中的图像 1,2 Acer Aspire V5-131-2629 Hard Drive Replacement: 步骤 11 中的图像 2,2
    • Pull the hard drive cage from the hard drive to separate the two.
结论
4等其他人完成本指南。
Nicole B Bosse
于10/27/19注册
175 声望
撰写一个指南
团队
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 的会员
UMASSD-O'CONNELL-F19S1G3
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 1,366
