跳转到主内容
Acer Aspire V5-131-2629 Cover Replacement
你所需要的
  1. Acer Aspire V5-131-2629 Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 Cover Replacement: 步骤 2 中的图像 1,1
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 Cover Replacement: 步骤 3 中的图像 1,1
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 Cover Replacement: 步骤 4 中的图像 1,2 Acer Aspire V5-131-2629 Cover Replacement: 步骤 4 中的图像 2,2
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 Cover Replacement, Cover: 步骤 5 中的图像 1,1
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 Cover Replacement: 步骤 6 中的图像 1,2 Acer Aspire V5-131-2629 Cover Replacement: 步骤 6 中的图像 2,2
    • Remove the cover by sliding it outwards and remove it from the device.
结论
另外一个人完成了本指南。
Aaron Almeida
于10/25/19注册
551 声望
创作了4篇指南
团队
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 的会员
UMASSD-O'CONNELL-F19S1G3
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 557
