跳转到主内容
Acer Aspire V5-122P-0468 Touchpad Replacement
你所需要的
  1. Acer Aspire V5-122P-0468 Touchpad Replacement, Battery: 步骤 1 中的图像 1,2 Acer Aspire V5-122P-0468 Touchpad Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the nine 4mm screws with a PH0 screwdriver.
    • Remove the two 6mm screws with a PH0 screwdriver.
  2. Acer Aspire V5-122P-0468 Touchpad Replacement: 步骤 2 中的图像 1,2 Acer Aspire V5-122P-0468 Touchpad Replacement: 步骤 2 中的图像 2,2
    • Remove the black rubber tab on the back of the computer
    • Remove the 4mm screw hidden underneath the black tab with a PH0 screwdriver.
  3. Acer Aspire V5-122P-0468 Touchpad Replacement: 步骤 3 中的图像 1,2 Acer Aspire V5-122P-0468 Touchpad Replacement: 步骤 3 中的图像 2,2
    • Orient the computer upside down, with the hinges facing away from you.
    • Find the black plastic piece in the SD card slot on the right side of the computer.
    • Remove the plastic piece by sliding it out of the SD card slot.
  4. Acer Aspire V5-122P-0468 Touchpad Replacement: 步骤 4 中的图像 1,3 Acer Aspire V5-122P-0468 Touchpad Replacement: 步骤 4 中的图像 2,3 Acer Aspire V5-122P-0468 Touchpad Replacement: 步骤 4 中的图像 3,3
    • Insert a spudger at these eight locations to disengage the plastic tabs from the housing cover, and pry apart.
    • Continue around the entire perimeter of the cover with the spudger.
    • Use a spudger to pry the cover around I/O ports.
  5. Acer Aspire V5-122P-0468 Touchpad Replacement: 步骤 5 中的图像 1,3 Acer Aspire V5-122P-0468 Touchpad Replacement: 步骤 5 中的图像 2,3 Acer Aspire V5-122P-0468 Touchpad Replacement: 步骤 5 中的图像 3,3
    • Remove the two 4mm screws using a PH0 screwdriver.
    • Depress the tabs holding the battery with a spudger.
    • Disconnect the battery connector from the motherboard using a spudger.
    • Pull the battery up and away from the laptop to remove.
  6. Acer Aspire V5-122P-0468 Touchpad Replacement, Touchpad: 步骤 6 中的图像 1,1
    • Use the spudger to pop up the latch on the ZIF connector.
    • Pull out the ribbon cable.
  7. Acer Aspire V5-122P-0468 Touchpad Replacement: 步骤 7 中的图像 1,3 Acer Aspire V5-122P-0468 Touchpad Replacement: 步骤 7 中的图像 2,3 Acer Aspire V5-122P-0468 Touchpad Replacement: 步骤 7 中的图像 3,3
    • Remove the three 2mm PH #0 screws.
    • Lift the metal tape up and off of the mounting bracket.
  8. Acer Aspire V5-122P-0468 Touchpad Replacement: 步骤 8 中的图像 1,1
    • Remove the metal mounting bracket from the bottom of the touchpad
  9. Acer Aspire V5-122P-0468 Touchpad Replacement: 步骤 9 中的图像 1,2 Acer Aspire V5-122P-0468 Touchpad Replacement: 步骤 9 中的图像 2,2
    • Carefully remove the foam pad from along the top edge of touchpad using a spudger.
    • This pad can be reused.
    • Remove the four 2mm PH #0 screws.
  10. Acer Aspire V5-122P-0468 Touchpad Replacement: 步骤 10 中的图像 1,1
    • Remove the touchpad from the laptop using a spudger.
结论
另外一个人完成了本指南。
Nat McCormick
于02/15/18注册
801 声望
创作了5篇指南
团队
USF Tampa, Team S16-G1, Boczar Spring 2018 USF Tampa, Team S16-G1, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S16G1
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 26
总计 1,665
