跳转到主内容
Acer Aspire V5-122P-0468 Network Card Replacement
你所需要的
  1. Acer Aspire V5-122P-0468 Network Card Replacement, Battery: 步骤 1 中的图像 1,2 Acer Aspire V5-122P-0468 Network Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the nine 4mm screws with a PH0 screwdriver.
    • Remove the two 6mm screws with a PH0 screwdriver.
  2. Acer Aspire V5-122P-0468 Network Card Replacement: 步骤 2 中的图像 1,2 Acer Aspire V5-122P-0468 Network Card Replacement: 步骤 2 中的图像 2,2
    • Remove the black rubber tab on the back of the computer
    • Remove the 4mm screw hidden underneath the black tab with a PH0 screwdriver.
  3. Acer Aspire V5-122P-0468 Network Card Replacement: 步骤 3 中的图像 1,2 Acer Aspire V5-122P-0468 Network Card Replacement: 步骤 3 中的图像 2,2
    • Orient the computer upside down, with the hinges facing away from you.
    • Find the black plastic piece in the SD card slot on the right side of the computer.
    • Remove the plastic piece by sliding it out of the SD card slot.
  4. Acer Aspire V5-122P-0468 Network Card Replacement: 步骤 4 中的图像 1,3 Acer Aspire V5-122P-0468 Network Card Replacement: 步骤 4 中的图像 2,3 Acer Aspire V5-122P-0468 Network Card Replacement: 步骤 4 中的图像 3,3
    • Insert a spudger at these eight locations to disengage the plastic tabs from the housing cover, and pry apart.
    • Continue around the entire perimeter of the cover with the spudger.
    • Use a spudger to pry the cover around I/O ports.
  5. Acer Aspire V5-122P-0468 Network Card Replacement: 步骤 5 中的图像 1,3 Acer Aspire V5-122P-0468 Network Card Replacement: 步骤 5 中的图像 2,3 Acer Aspire V5-122P-0468 Network Card Replacement: 步骤 5 中的图像 3,3
    • Remove the two 4mm screws using a PH0 screwdriver.
    • Depress the tabs holding the battery with a spudger.
    • Disconnect the battery connector from the motherboard using a spudger.
    • Pull the battery up and away from the laptop to remove.
  6. Acer Aspire V5-122P-0468 Network Card Replacement, Network Card: 步骤 6 中的图像 1,1
    • Remove the wire connector from the network card using a plastic opening tool.
  7. Acer Aspire V5-122P-0468 Network Card Replacement: 步骤 7 中的图像 1,1
    • Remove the 3mm Phillips #0 screw.
  8. Acer Aspire V5-122P-0468 Network Card Replacement: 步骤 8 中的图像 1,1
    • Gently slide the network card out of the motherboard connector.
结论
Nat McCormick
于02/15/18注册
801 声望
创作了5篇指南
团队
USF Tampa, Team S16-G1, Boczar Spring 2018 USF Tampa, Team S16-G1, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S16G1
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 9
总计 547
