跳转到主内容
Acer Aspire V5-122P-0468 Hard Drive Replacement
你所需要的
  1. Acer Aspire V5-122P-0468 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 Acer Aspire V5-122P-0468 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the nine 4mm screws with a PH0 screwdriver.
    • Remove the two 6mm screws with a PH0 screwdriver.
  2. Acer Aspire V5-122P-0468 Hard Drive Replacement: 步骤 2 中的图像 1,2 Acer Aspire V5-122P-0468 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Remove the black rubber tab on the back of the computer
    • Remove the 4mm screw hidden underneath the black tab with a PH0 screwdriver.
  3. Acer Aspire V5-122P-0468 Hard Drive Replacement: 步骤 3 中的图像 1,2 Acer Aspire V5-122P-0468 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Orient the computer upside down, with the hinges facing away from you.
    • Find the black plastic piece in the SD card slot on the right side of the computer.
    • Remove the plastic piece by sliding it out of the SD card slot.
  4. Acer Aspire V5-122P-0468 Hard Drive Replacement: 步骤 4 中的图像 1,3 Acer Aspire V5-122P-0468 Hard Drive Replacement: 步骤 4 中的图像 2,3 Acer Aspire V5-122P-0468 Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Insert a spudger at these eight locations to disengage the plastic tabs from the housing cover, and pry apart.
    • Continue around the entire perimeter of the cover with the spudger.
    • Use a spudger to pry the cover around I/O ports.
  5. Acer Aspire V5-122P-0468 Hard Drive Replacement: 步骤 5 中的图像 1,3 Acer Aspire V5-122P-0468 Hard Drive Replacement: 步骤 5 中的图像 2,3 Acer Aspire V5-122P-0468 Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Remove the two 4mm screws using a PH0 screwdriver.
    • Depress the tabs holding the battery with a spudger.
    • Disconnect the battery connector from the motherboard using a spudger.
    • Pull the battery up and away from the laptop to remove.
  6. Acer Aspire V5-122P-0468 Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 1,3 Acer Aspire V5-122P-0468 Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 2,3 Acer Aspire V5-122P-0468 Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 3,3
    • Use a plastic opening tool to pop the latch up on the ZIF connector up.
    • Pull out the ribbon cable to disconnect it from one side.
    • The cable can be left connected to the other side.
    • Remove the black isolation pad.
  7. Acer Aspire V5-122P-0468 Hard Drive Replacement: 步骤 7 中的图像 1,2 Acer Aspire V5-122P-0468 Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Disconnect the data connector from the motherboard using a plastic opening tool.
  8. Acer Aspire V5-122P-0468 Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Remove three 4mm Phillips #0 screws.
    • Remove hard drive with rail attached from laptop.
  9. Acer Aspire V5-122P-0468 Hard Drive Replacement: 步骤 9 中的图像 1,2 Acer Aspire V5-122P-0468 Hard Drive Replacement: 步骤 9 中的图像 2,2
    • Remove the four 3mm Phillips #0 screws located on the side of the rails.
    • Separate the hard drive from the mounting rail.
结论
2等其他人完成本指南。
Nat McCormick
于02/15/18注册
801 声望
创作了5篇指南
团队
USF Tampa, Team S16-G1, Boczar Spring 2018 USF Tampa, Team S16-G1, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S16G1
5 名成员
创作了10篇指南
一条评论
What would be the correct hard drive upgrade. Something to make this laptop faster mines the 500gb the processor is and dual core prossee a4-1250
Lara Mcneese - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 20
总计 2,337
