跳转到主内容
Acer Aspire V3-771G Hard Drive Replacement
你所需要的
  1. Acer Aspire V3-771G Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 Acer Aspire V3-771G Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Shut down the laptop.
    • Remove the power charging cord from the laptop.
  2. Acer Aspire V3-771G Hard Drive Replacement: 步骤 2 中的图像 1,3 Acer Aspire V3-771G Hard Drive Replacement: 步骤 2 中的图像 2,3 Acer Aspire V3-771G Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Flip the laptop over, and find the battery compartment.
    • Use your fingers to move the orange slider located just below the battery compartment to the right.
    • Do not touch the battery connectors on the battery or laptop.
    • Lift the battery up and remove from the compartment.
  3. Acer Aspire V3-771G Hard Drive Replacement: 步骤 3 中的图像 1,2 Acer Aspire V3-771G Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Using the screwdriver, remove the nine 8 mm screws from the panel on the back of the laptop.
    • Gently lift the panel up from the open slot, use the opening tools as necessary, to free the panel from the laptop.
  4. Acer Aspire V3-771G Hard Drive Replacement: 步骤 4 中的图像 1,2 Acer Aspire V3-771G Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Remove the two screws holding the hard drive sled in place.
    • While grounding yourself, gently pull the black tag straight back, not up, to free the hard drive.
  5. Acer Aspire V3-771G Hard Drive Replacement: 步骤 5 中的图像 1,3 Acer Aspire V3-771G Hard Drive Replacement: 步骤 5 中的图像 2,3 Acer Aspire V3-771G Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Using the screwdriver, remove the four 4 mm screws from the hard drive sled.
    • Carefully remove the hard drive. A new one may now be installed.
结论
9等其他人完成本指南。
David Walker
于10/11/14注册
341 声望
撰写一个指南
团队
USF Tampa, Team 1-36, Donnelly Fall 2014 USF Tampa, Team 1-36, Donnelly Fall 2014 的会员
USFT-DONNELLY-F14S1G36
1 名成员
创作了1篇指南
一条评论
Please pardon my inquiry. Is the same replacement can be done to Acer Aspire V3-572P-540V? Any reply will be appreciated.
b6789b - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 34
总计 13,624
