跳转到主内容
Acer Aspire V3-551-8887 Motherboard Replacement
你所需要的
  1. Acer Aspire V3-551-8887 Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  2. Acer Aspire V3-551-8887 Motherboard Replacement: 步骤 2 中的图像 1,2 Acer Aspire V3-551-8887 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to pry the panel up from the laptop case and remove it.
    • The laptop should now be open with the RAM and wifi chip now accessible.
  3. Acer Aspire V3-551-8887 Motherboard Replacement, USB Ports: 步骤 3 中的图像 1,1
    • Locate the wifi chip.
  4. Acer Aspire V3-551-8887 Motherboard Replacement: 步骤 4 中的图像 1,2 Acer Aspire V3-551-8887 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the 5 mm Phillips #1 screw holding the wifi chip in place.
    • Carefully remove the wifi chip.
  5. Acer Aspire V3-551-8887 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the 8, 9 mm Phillips #1 screws holding the panel in place.
  6. Acer Aspire V3-551-8887 Motherboard Replacement: 步骤 6 中的图像 1,2 Acer Aspire V3-551-8887 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Flip the computer over, and with a spudger, remove the black panel directly below the keyboard.
    • Remove the panel and flip it up onto the keyboard
  7. Acer Aspire V3-551-8887 Motherboard Replacement: 步骤 7 中的图像 1,2 Acer Aspire V3-551-8887 Motherboard Replacement: 步骤 7 中的图像 2,2
    • With the panel removed, locate the USB port ribbon cable connecting to the motherboard.
    • Carefully disconnect the ribbon cable.
  8. Acer Aspire V3-551-8887 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Unscrew the 5 mm Phillips #1 screw holding the USB ports in place.
  9. Acer Aspire V3-551-8887 Motherboard Replacement: 步骤 9 中的图像 1,1
    • The USB ports can now be removed from the laptop.
  10. Acer Aspire V3-551-8887 Motherboard Replacement, Keyboard: 步骤 10 中的图像 1,1
    • Flip the laptop and remove all 10 of the remaining 9mm screws from the back.
  11. Acer Aspire V3-551-8887 Motherboard Replacement: 步骤 11 中的图像 1,2 Acer Aspire V3-551-8887 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Use a spudger to gently lift the keyboard.
  12. Acer Aspire V3-551-8887 Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,1
    • Remove the two 10 mm Phillips #1 screws connecting the motherboard to the case.
  13. Acer Aspire V3-551-8887 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Disconnect the 4 ribbon cables connected to the motherboard.
    • Some ribbon cable connections may not be accessible until after beginning to lift.
  14. Acer Aspire V3-551-8887 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Very carefully lift the motherboard.
    • Do not force the board. If stuck, check that the ports on the left are not stuck, that no wires are still attached, and no screws are still in.
结论
4等其他人完成本指南。
Alexander Lazar
于04/22/14注册
357 声望
创作了2篇指南
团队
Cal Poly, Team 8-8, Regan Spring 2014 Cal Poly, Team 8-8, Regan Spring 2014 的会员
CPSU-REGAN-S14S8G8
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 5,308
