跳转到主内容
Acer Aspire V3-551-8887 Keyboard Replacement
你所需要的
  1. Acer Aspire V3-551-8887 Keyboard Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  2. Acer Aspire V3-551-8887 Keyboard Replacement: 步骤 2 中的图像 1,2 Acer Aspire V3-551-8887 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to pry the panel up from the laptop case and remove it.
    • The laptop should now be open with the RAM and wifi chip now accessible.
  3. Acer Aspire V3-551-8887 Keyboard Replacement, USB Ports: 步骤 3 中的图像 1,1
    • Locate the wifi chip.
  4. Acer Aspire V3-551-8887 Keyboard Replacement: 步骤 4 中的图像 1,2 Acer Aspire V3-551-8887 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Remove the 5 mm Phillips #1 screw holding the wifi chip in place.
    • Carefully remove the wifi chip.
  5. Acer Aspire V3-551-8887 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Remove the 8, 9 mm Phillips #1 screws holding the panel in place.
  6. Acer Aspire V3-551-8887 Keyboard Replacement: 步骤 6 中的图像 1,2 Acer Aspire V3-551-8887 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Flip the computer over, and with a spudger, remove the black panel directly below the keyboard.
    • Remove the panel and flip it up onto the keyboard
  7. Acer Aspire V3-551-8887 Keyboard Replacement: 步骤 7 中的图像 1,2 Acer Aspire V3-551-8887 Keyboard Replacement: 步骤 7 中的图像 2,2
    • With the panel removed, locate the USB port ribbon cable connecting to the motherboard.
    • Carefully disconnect the ribbon cable.
  8. Acer Aspire V3-551-8887 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Unscrew the 5 mm Phillips #1 screw holding the USB ports in place.
  9. Acer Aspire V3-551-8887 Keyboard Replacement: 步骤 9 中的图像 1,1
    • The USB ports can now be removed from the laptop.
  10. Acer Aspire V3-551-8887 Keyboard Replacement, Keyboard: 步骤 10 中的图像 1,1
    • Flip the laptop and remove all 10 of the remaining 9mm screws from the back.
  11. Acer Aspire V3-551-8887 Keyboard Replacement: 步骤 11 中的图像 1,2 Acer Aspire V3-551-8887 Keyboard Replacement: 步骤 11 中的图像 2,2
    • Use a spudger to gently lift the keyboard.
结论
3等其他人完成本指南。
Alexander Lazar
于04/22/14注册
357 声望
创作了2篇指南
团队
Cal Poly, Team 8-8, Regan Spring 2014 Cal Poly, Team 8-8, Regan Spring 2014 的会员
CPSU-REGAN-S14S8G8
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 25
总计 6,635
