跳转到主内容
Acer Aspire V3-551-8887 Back Panel Replacement
你所需要的
  1. Acer Aspire V3-551-8887 Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  2. Acer Aspire V3-551-8887 Back Panel Replacement: 步骤 2 中的图像 1,2 Acer Aspire V3-551-8887 Back Panel Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to pry the panel up from the laptop case and remove it.
    • The laptop should now be open with the RAM and wifi chip now accessible.
结论
另外一个人完成了本指南。
Jacob Lesinski
于04/22/14注册
143 声望
撰写一个指南
团队
Cal Poly, Team 8-8, Regan Spring 2014 Cal Poly, Team 8-8, Regan Spring 2014 的会员
CPSU-REGAN-S14S8G8
4 名成员
创作了7篇指南
一条评论
Is the hard drive accessible for replacement from the bottom? I see black stuff over the drive with the WIFI cables going underneath. Is that removable so one can access the drive from the bottom, or is it accessible from under the keyboard?
danwat1234 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,754
