跳转到主内容
Acer Aspire V3-551-8469 Fan Replacement
你所需要的
  1. Acer Aspire V3-551-8469 Fan Replacement, Fan: 步骤 1 中的图像 1,2 Acer Aspire V3-551-8469 Fan Replacement, Fan: 步骤 1 中的图像 2,2
    • To release the battery, slide the orange tab to the right with a spudger.
    • The battery is now released and can be picked up and set to the side.
  2. Acer Aspire V3-551-8469 Fan Replacement: 步骤 2 中的图像 1,3 Acer Aspire V3-551-8469 Fan Replacement: 步骤 2 中的图像 2,3 Acer Aspire V3-551-8469 Fan Replacement: 步骤 2 中的图像 3,3
    • Remove the 16 5.3 mm Phillips #0 screws.
    • Remove the three 3 mm Phillips #00 screws.
  3. Acer Aspire V3-551-8469 Fan Replacement: 步骤 3 中的图像 1,3 Acer Aspire V3-551-8469 Fan Replacement: 步骤 3 中的图像 2,3 Acer Aspire V3-551-8469 Fan Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the back panel, and remove the white cable from the wifi chip using a pair of tweezers.
  4. Acer Aspire V3-551-8469 Fan Replacement: 步骤 4 中的图像 1,1
    • Using a Phillips head #0 screwdriver, remove the four 5.3 mm screws.
  5. Acer Aspire V3-551-8469 Fan Replacement: 步骤 5 中的图像 1,3 Acer Aspire V3-551-8469 Fan Replacement: 步骤 5 中的图像 2,3 Acer Aspire V3-551-8469 Fan Replacement: 步骤 5 中的图像 3,3
    • Flip the computer over and remove the touchpad cover and keyboard.
    • Be careful doing this since there are two ribbon cables connecting both panels to the motherboard.
  6. Acer Aspire V3-551-8469 Fan Replacement: 步骤 6 中的图像 1,2 Acer Aspire V3-551-8469 Fan Replacement: 步骤 6 中的图像 2,2
    • Disconnect the four ribbon cables.
  7. Acer Aspire V3-551-8469 Fan Replacement: 步骤 7 中的图像 1,1
    • Remove the five 5.3 mm Phillips #0 screws.
  8. Acer Aspire V3-551-8469 Fan Replacement: 步骤 8 中的图像 1,1
    • Gently lift up the motherboard and slide it out to the right.
    • Do not force the board. If stuck, check that the ports on the left are loose, that no wires are still attached, and no screws are still in.
  9. Acer Aspire V3-551-8469 Fan Replacement: 步骤 9 中的图像 1,1
    • Flip the motherboard over and using a pair of tweezers, remove the cable.
  10. Acer Aspire V3-551-8469 Fan Replacement: 步骤 10 中的图像 1,2 Acer Aspire V3-551-8469 Fan Replacement: 步骤 10 中的图像 2,2
    • Remove the six 2mm Phillips #00 screws.
  11. Acer Aspire V3-551-8469 Fan Replacement: 步骤 11 中的图像 1,1
    • Using a pair of tweezers, remove the cable.
结论
另外一个人完成了本指南。
Maritsa Garcia
于10/22/18注册
800 声望
创作了5篇指南
团队
Baylor, Team S1-G4, Williams Fall 2018 Baylor, Team S1-G4, Williams Fall 2018 的会员
BU-WILLIAMS-F18S1G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 8
总计 602
