跳转到主内容
Acer Aspire V3-472p-324J Battery Replacement
你所需要的
  1. Acer Aspire V3-472p-324J Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • First you will flip your laptop upside down so the battery side is facing up.
  2. Acer Aspire V3-472p-324J Battery Replacement: 步骤 2 中的图像 1,1
    • Once upside down, you will find the battery here.
  3. Acer Aspire V3-472p-324J Battery Replacement: 步骤 3 中的图像 1,1
    • In order to access the battery you will need to remove the 18 5mm screws. Using your Phillips J1 bit remove the screws.
  4. Acer Aspire V3-472p-324J Battery Replacement: 步骤 4 中的图像 1,1
    • Stand your laptop up on its side to find the seams.
  5. Acer Aspire V3-472p-324J Battery Replacement: 步骤 5 中的图像 1,1
    • Carefully insert your plastic opening tool into the seam and move up and down to separate the back panel from the front. Repeat this process all around the laptop until all sides have been separated.
  6. Acer Aspire V3-472p-324J Battery Replacement: 步骤 6 中的图像 1,1
    • Remove the bottom plastic panel from the top.
  7. Acer Aspire V3-472p-324J Battery Replacement: 步骤 7 中的图像 1,1
    • Locate the laptop speaker connector.
  8. Acer Aspire V3-472p-324J Battery Replacement: 步骤 8 中的图像 1,1
    • Gently remove the speaker connector.
  9. Acer Aspire V3-472p-324J Battery Replacement: 步骤 9 中的图像 1,1
    • Once you have disconnected the speakers you will now have two separate pieces.
  10. Acer Aspire V3-472p-324J Battery Replacement: 步骤 10 中的图像 1,1
    • The battery is located on the bottom panel.
  11. Acer Aspire V3-472p-324J Battery Replacement: 步骤 11 中的图像 1,1
    • Use the plastic lever here and slide it to the side.
  12. Acer Aspire V3-472p-324J Battery Replacement: 步骤 12 中的图像 1,1
    • While holding the plastic lever, gently separate the battery from the bottom panel of the laptop.
  13. Acer Aspire V3-472p-324J Battery Replacement: 步骤 13 中的图像 1,1
    • Take the old battery and dispose per manufacturers website.
结论
3等其他人完成本指南。
Chris Arnone
于10/17/15注册
364 声望
撰写一个指南
团队
Gateway, Team 1-5, Kuhn Fall 2015 Gateway, Team 1-5, Kuhn Fall 2015 的会员
GCC-KUHN-F15S1G5
1 名成员
创作了1篇指南
2条评论
You don't have to remove the cover to remove the battery. Step 11 can be done with the cover on. Slide the switch over. Battery pops right out.
darren - 回复
Yes don’t need to take cover off -battery can be removed by using a pen/screwdriver to slide the tab to the side & battery releases.
It has a very small image of an arrow with a pen next to it. Very misleading (I tried to push it in first!)
If you wiggle the battery, you can see the battery release tab moves with it :-)
oewxiblrjrffklkifb@ttirv.net - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 18
总计 3,435
