跳转到主内容
Acer Aspire TimelineX 4830T-6682 RAM Replacement
你所需要的
  1. Acer Aspire TimelineX 4830T-6682 RAM Replacement, Lower Back Panel: 步骤 1 中的图像 1,3 Acer Aspire TimelineX 4830T-6682 RAM Replacement, Lower Back Panel: 步骤 1 中的图像 2,3 Acer Aspire TimelineX 4830T-6682 RAM Replacement, Lower Back Panel: 步骤 1 中的图像 3,3
    • Remove the single screw with a Phillips #0 screwdriver.
    • Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
    • The other way to remove the panel is by sliding it away from the laptop. The difficulty of sliding it depends on the condition of your laptop.
  2. Acer Aspire TimelineX 4830T-6682 RAM Replacement, RAM: 步骤 2 中的图像 1,3 Acer Aspire TimelineX 4830T-6682 RAM Replacement, RAM: 步骤 2 中的图像 2,3 Acer Aspire TimelineX 4830T-6682 RAM Replacement, RAM: 步骤 2 中的图像 3,3
    • After the panel has been removed, locate the RAM. It should be on the lower right.
    • There are pins around the RAM that need to be pulled back. After the pins are removed, pull the RAM chip towards you to remove it.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 436
