跳转到主内容
Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement
你所需要的
  1. Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement, Lower Back Panel: 步骤 1 中的图像 1,3 Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement, Lower Back Panel: 步骤 1 中的图像 2,3 Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement, Lower Back Panel: 步骤 1 中的图像 3,3
    • Remove the single screw with a Phillips #0 screwdriver.
    • Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
    • The other way to remove the panel is by sliding it away from the laptop. The difficulty of sliding it depends on the condition of your laptop.
  2. Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement, Hard Disk Drive: 步骤 2 中的图像 1,3 Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement, Hard Disk Drive: 步骤 2 中的图像 2,3 Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement, Hard Disk Drive: 步骤 2 中的图像 3,3
    • Remove four silver screws, highlighted with red circles with a Phillips #1 screwdriver
    • Remove two black screws, highlighted with orange circles with a Phillips #1 screwdriver
  3. Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement: 步骤 3 中的图像 1,2 Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement: 步骤 3 中的图像 2,2
    • Pick the hard drive up from the laptop. Keep your hand off the circuit board since the battery is still connected, and voltage might be present
    • Disconnect the SATA connector by pulling the black plastic marked in the pictures horizontally away from the hard drive
结论
Jon Brunsell
于07/10/19注册
592 声望
创作了6篇指南
团队
IUPUI, Team S1-G1, Beck Spring 2020 IUPUI, Team S1-G1, Beck Spring 2020 的会员
IUPUI-BECK-S20S1G1
3 名成员
创作了6篇指南
2条评论
Thanks for the guide. Do you know how to detach the SATA cable from the motherboard? If not, I would really appreciate your help if you know where I should look for an answer. Thanks so much for your help!!
Sasha Maleki - 回复
Hello,
I am glad you were able to use the guide. The connector is about two centimeters under the cover on the back side of the motherboard. The SATA cable can be removed once the motherboard is detached from the frame.
Best regards,
Jon
Jon Brunsell - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 24
总计 1,113
