简介
A working cooling fan in laptops is a critical component because the processor, and graphic IC’s would overheat without it. Fans are a wearout part that will eventually need replacing.
This guide provides simple steps to replace the Fan on the Acer Aspire TimelineX 4830T-6682 using minimal tools that can be acquired locally, or through iFixit. Please make sure and follow the prerequisite procedures.
你所需要的
Remove the single screw with a Phillips #0 screwdriver.
Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
Remove the eleven screws that hold that back panel to the laptop using a J0 Phillips screwdriver bit.
在这个步骤中使用的工具:Tweezers$3.99
Place the laptop in the upright position, the lower front touchpad panel should be easily detatched at this point.
Remove the lower front touchpad panel by using an angled tweezers to disconnect the only wired tape connected to the motherboard.
The battery will be on the side closest to the screen.
Gently lift it out. It will still be attached by white, red, and black wires.
另外一个人完成了本指南。
2条评论
The fans are not generic even though the same fan might be used for several laptop models the frame of the fan might be different. A replacement fan can be purchased online by searching for the laptop model and fan. Here is an example of an Amazon search I did for the Acer Aspire 4830T fan:
https://www.amazon.com/wangpeng-Cooling-...
Best Regards
