跳转到主内容
Acer Aspire TimelineX 4820T-6645 RAM Replacement
你所需要的
  1. Acer Aspire TimelineX 4820T-6645 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Power down the laptop.
    • Turn the laptop over so the bottom is facing up and the battery is facing towards you.
  2. Acer Aspire TimelineX 4820T-6645 RAM Replacement: 步骤 2 中的图像 1,1
    • The tab on the right is a locking tab. Slide this tab to the right to unlock it (the red should now be showing).
    • Slide the left tab to the left and hold it there.
  3. Acer Aspire TimelineX 4820T-6645 RAM Replacement: 步骤 3 中的图像 1,2 Acer Aspire TimelineX 4820T-6645 RAM Replacement: 步骤 3 中的图像 2,2
    • While holding the left tab to the left the battery should easily pull out of the laptop.
  4. Acer Aspire TimelineX 4820T-6645 RAM Replacement, RAM: 步骤 4 中的图像 1,2 Acer Aspire TimelineX 4820T-6645 RAM Replacement, RAM: 步骤 4 中的图像 2,2
    • Flip the laptop over and locate the hard drive cover. This is a L shaped plastic cover and has 5 PH#1 8mm screws located around the outside edge. The screw locations are denoted by red circles in the figure.
    • Remove those five screws and then remove the cover.
  5. Acer Aspire TimelineX 4820T-6645 RAM Replacement: 步骤 5 中的图像 1,3 Acer Aspire TimelineX 4820T-6645 RAM Replacement: 步骤 5 中的图像 2,3 Acer Aspire TimelineX 4820T-6645 RAM Replacement: 步骤 5 中的图像 3,3
    • On either side of the RAM module, there will be two metal tabs. Slide both tabs away from the memory module and the RAM module will pop loose.
    • The location of the tabs are shown by two red circles. Once these tabs are pulled to the side the RAM will pop up. Pulling straight back on the module will remove it.
    • Be careful, these metal tabs may break if you apply too much force to them.
结论
Michael Kilmartin
于03/26/19注册
331 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 8
总计 272
