跳转到主内容
Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement
你所需要的
  1. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Power down the laptop.
    • Turn the laptop over so the bottom is facing up and the battery is facing towards you.
  2. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • The tab on the right is a locking tab. Slide this tab to the right to unlock it (the red should now be showing).
    • Slide the left tab to the left and hold it there.
  3. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: 步骤 3 中的图像 1,2 Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • While holding the left tab to the left the battery should easily pull out of the laptop.
  4. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,2 Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Place laptop bottom side up, and use a Phillips #1 screwdriver to unscrew the five 8 mm screws from the back panel.
  5. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • After removing the back panel, use a Phillips #1 screwdriver to unscrew the two 8 mm screws that hold the retaining piece to the frame.
  6. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: 步骤 6 中的图像 1,2 Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Pull the plastic tab toward the frame to disconnect the hard drive SATA.
  7. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Remove the hard drive from the laptop, and use a Phillips #1 screwdriver to unscrew the two 3 mm screws that secure the retaining piece to the hard drive.
结论
Ian Smiley
于03/26/19注册
109 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 579
