跳转到主内容
Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement
你所需要的
  1. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn your laptop over, and find the laptop battery release button locks for your Acer laptop.
  2. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: 步骤 2 中的图像 1,3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: 步骤 2 中的图像 2,3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: 步骤 2 中的图像 3,3
    • Hold the battery release button, and pull the battery out of the laptop.
  3. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Fan: 步骤 3 中的图像 1,3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Fan: 步骤 3 中的图像 2,3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Fan: 步骤 3 中的图像 3,3
    • Remove battery before beginning.
    • Use a Phillips #0 screwdriver to remove the 5 screws from the bottom cover.
    • Pry open the cover using the Spudger tool.
  4. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: 步骤 4 中的图像 1,3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: 步骤 4 中的图像 2,3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: 步骤 4 中的图像 3,3
    • Remove the keyboard with a plastic opening tool or spudger.
    • There is a plastic film that needs to be gently peeled from the laptop base.
    • Use caution when removing the keyboard as it is fragile.
  5. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: 步骤 5 中的图像 1,2 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the 4 screws from the motherboard shield.
  6. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: 步骤 6 中的图像 1,2 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: 步骤 6 中的图像 2,2
    • Remove the motherboard from the base of the laptop by unscrew the screw drivers using PH0 mm Phillips Head.
    • Carefully remove the charger attachment in the top left.
  7. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: 步骤 7 中的图像 1,3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: 步骤 7 中的图像 2,3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: 步骤 7 中的图像 3,3
    • Carefully remove the fan from the motherboard by detaching the plastic insert as seen in the pictures
  8. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Bluetooth: 步骤 8 中的图像 1,3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Bluetooth: 步骤 8 中的图像 2,3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Bluetooth: 步骤 8 中的图像 3,3
    • Detach the covered wires that connect the motherboard to the Bluetooth.
    • Remove the Bluetooth module by hand to then replace it.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 34
总计 799
