跳转到主内容
Acer Aspire TimelineU M5-581T-6807 Battery Replacement
你所需要的
  1. Acer Aspire TimelineU M5-581T-6807 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the screws, indicated by the circles in the picture, from the back panel using the PH1 attachment.
  2. Acer Aspire TimelineU M5-581T-6807 Battery Replacement: 步骤 2 中的图像 1,1
    • Note: The back panel cannot be removed. Flip the laptop and remove the keyboard to access the components.
  3. Acer Aspire TimelineU M5-581T-6807 Battery Replacement: 步骤 3 中的图像 1,1
    • With the keyboard removed, Locate the battery as seen in the picture. Remove the wire connection above the battery by hand. Grab all the wires and shim the connector out of position.
  4. Acer Aspire TimelineU M5-581T-6807 Battery Replacement: 步骤 4 中的图像 1,1
    • Locate and remove the Phillips #1 screw holding the battery in place using the PH1 attachment.
  5. Acer Aspire TimelineU M5-581T-6807 Battery Replacement: 步骤 5 中的图像 1,1
    • Pry the battery upwards, using the iFixIt opening tool, to remove it out of the holder.
  6. Acer Aspire TimelineU M5-581T-6807 Battery Replacement: 步骤 6 中的图像 1,1
    • Now the battery is exposed and ready for replacement.
结论
6等其他人完成本指南。
Edwin VanBaale
于04/09/19注册
256 声望
撰写一个指南
团队
IUPUI, Team S1-G1, Hovde Spring 2019 IUPUI, Team S1-G1, Hovde Spring 2019 的会员
IUPUI-HOVDE-S19S1G1
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 25
总计 2,254
