跳转到主内容
Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement
你所需要的
  1. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Wedge your plastic opening tool into the crevice between the volume button and casing to create space.
    • Slide the plastic opening tool along this crevice to pry apart the backing of the tablet.
  2. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 步骤 2 中的图像 1,3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 步骤 2 中的图像 2,3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 步骤 2 中的图像 3,3
    • There are four zero insertion force connectors that need to be removed.
    • Use your plastic opening tool to flip up the black clips that secure the ribbon cables to the motherboard.
    • Once the clips are flipped up, the ribbon cables will be safe to remove.
  3. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 步骤 3 中的图像 1,3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 步骤 3 中的图像 2,3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Use your plastic opening tool to pry up and lift the antenna cables from the motherboard.
    • The connectors are delicate so use a gentle touch when prying them.
  4. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 步骤 4 中的图像 1,3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 步骤 4 中的图像 2,3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 步骤 4 中的图像 3,3
    • To remove the four bundle cable connectors, push against the edges of the connector to loosen it up.
    • Pull the cable away from the connector.
  5. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 步骤 5 中的图像 1,2 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Use your screwdriver with the Phillips PH000 attachment to remove the three 4mm screws.
    • Remove the motherboard from the tablet.
结论
9等其他人完成本指南。
Max Francois
于09/28/16注册
684 声望
创作了2篇指南
团队
USF Tampa, Team 3-4, Passmore Fall 2016 USF Tampa, Team 3-4, Passmore Fall 2016 的会员
USFT-PASSMORE-F16S3G4
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 7,357
