跳转到主内容
Acer Aspire S3-951-6432 Wi-Fi Card Replacement
你所需要的
  1. Acer Aspire S3-951-6432 Wi-Fi Card Replacement, Battery: 步骤 1 中的图像 1,3 Acer Aspire S3-951-6432 Wi-Fi Card Replacement, Battery: 步骤 1 中的图像 2,3 Acer Aspire S3-951-6432 Wi-Fi Card Replacement, Battery: 步骤 1 中的图像 3,3
    • Keeping it closed, turn the laptop upside down.
    • With the Phillips #0 screwdriver, remove the twelve 5 mm screws that hold the laptop together.
    • Insert the plastic opening tool between the plastic casings to pull the bottom lid of the laptop up.
    • You do not need to pull the lid all the way off.
  2. Acer Aspire S3-951-6432 Wi-Fi Card Replacement: 步骤 2 中的图像 1,3 Acer Aspire S3-951-6432 Wi-Fi Card Replacement: 步骤 2 中的图像 2,3 Acer Aspire S3-951-6432 Wi-Fi Card Replacement: 步骤 2 中的图像 3,3
    • Locate the six cables that are connected to the motherboard. The cable with the white strip is located underneath the cable with the orange strip.
    • Using the plastic opening tool on one side and your fingernail on the other, wedge each cable out of its socket.
    • The battery is now disconnected. If you want to remove the battery, follow the remaining steps in this guide. However, if you only wish to disconnect the battery to do other internal work, skip the remaining steps in this guide and continue on to other guides.
  3. Acer Aspire S3-951-6432 Wi-Fi Card Replacement: 步骤 3 中的图像 1,1
    • With the Phillips #0 screwdriver, remove the two 5 mm screws that are located above the long black piece of the battery.
  4. Acer Aspire S3-951-6432 Wi-Fi Card Replacement: 步骤 4 中的图像 1,3 Acer Aspire S3-951-6432 Wi-Fi Card Replacement: 步骤 4 中的图像 2,3 Acer Aspire S3-951-6432 Wi-Fi Card Replacement: 步骤 4 中的图像 3,3
    • Locate the two speakers for this laptop that are connected above the battery by a thin red cord.
    • Using the Phillips #0 screwdriver, remove the two 3 mm screws holding the left speaker in place.
    • Pull the left speaker up along with the red cord and leave it off to the right side.
    • If you plan to disassemble the laptop down to the motherboard, you will also need to remove the two 3 mm screws holding the right-side speaker in place with a Phillips #0 screwdriver.
  5. Acer Aspire S3-951-6432 Wi-Fi Card Replacement: 步骤 5 中的图像 1,1
    • Without bending it, lift the entire battery (both the long black piece and the rectangular blue piece) straight up. Place it off to one side.
  6. Acer Aspire S3-951-6432 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 6 中的图像 1,2 Acer Aspire S3-951-6432 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 6 中的图像 2,2
    • Locate the Wi-Fi card (it is near the black rectangular hard drive).
  7. Acer Aspire S3-951-6432 Wi-Fi Card Replacement: 步骤 7 中的图像 1,3 Acer Aspire S3-951-6432 Wi-Fi Card Replacement: 步骤 7 中的图像 2,3 Acer Aspire S3-951-6432 Wi-Fi Card Replacement: 步骤 7 中的图像 3,3
    • Lift up and remove the two cables attached to the Wi-Fi card (one is white and one is black) with the spudger tool.
  8. Acer Aspire S3-951-6432 Wi-Fi Card Replacement: 步骤 8 中的图像 1,2 Acer Aspire S3-951-6432 Wi-Fi Card Replacement: 步骤 8 中的图像 2,2
    • Remove the single 3 mm screw located on the top-right side of the Wi-Fi card using the Phillips #0 screwdriver.
    • After replacing the Wi-Fi card, make sure that the cables are aligned. Otherwise, you could damage the metal connectors on the chip.
  9. Acer Aspire S3-951-6432 Wi-Fi Card Replacement: 步骤 9 中的图像 1,3 Acer Aspire S3-951-6432 Wi-Fi Card Replacement: 步骤 9 中的图像 2,3 Acer Aspire S3-951-6432 Wi-Fi Card Replacement: 步骤 9 中的图像 3,3
    • Lift and remove the Wi-Fi card.
结论
Cynthia Bennett
于10/17/18注册
584 声望
创作了5篇指南
团队
UW Tacoma, Team S1-G1, Rose Fall 2018 UW Tacoma, Team S1-G1, Rose Fall 2018 的会员
UWT-ROSE-F18S1G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 20
总计 1,699
