跳转到主内容
Acer Aspire S3-391-6046 Screen Replacement
你所需要的
  1. Acer Aspire S3-391-6046 Screen Replacement, Screen: 步骤 1 中的图像 1,3 Acer Aspire S3-391-6046 Screen Replacement, Screen: 步骤 1 中的图像 2,3 Acer Aspire S3-391-6046 Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Slide the plastic opening tool underneath the frame of your device.
    • Slide the plastic opening tool all around the frame until the entire frame becomes loose and comes off.
  2. Acer Aspire S3-391-6046 Screen Replacement: 步骤 2 中的图像 1,3 Acer Aspire S3-391-6046 Screen Replacement: 步骤 2 中的图像 2,3 Acer Aspire S3-391-6046 Screen Replacement: 步骤 2 中的图像 3,3
    • On the bottom left of the screen there is a black cable with a piece of white tape over it. Remove the white tape by peeling it off.
    • Slide your opening tool underneath the front of the cable, and pull the cable upwards to disconnect it from its socket.
  3. Acer Aspire S3-391-6046 Screen Replacement: 步骤 3 中的图像 1,3 Acer Aspire S3-391-6046 Screen Replacement: 步骤 3 中的图像 2,3 Acer Aspire S3-391-6046 Screen Replacement: 步骤 3 中的图像 3,3
    • Peel the silver tape from the corner of your laptop until it fully comes off.
  4. Acer Aspire S3-391-6046 Screen Replacement: 步骤 4 中的图像 1,3 Acer Aspire S3-391-6046 Screen Replacement: 步骤 4 中的图像 2,3 Acer Aspire S3-391-6046 Screen Replacement: 步骤 4 中的图像 3,3
    • Remove the screen by grabbing the edges of the screen and pulling forward.
结论
6等其他人完成本指南。
2条评论
Hi! Apparently three films came off with the LCD. Clear,gray and black what are they?
Coolboy_Awesome - 回复
Thank you. Excellent instructions allowing me to replace LCD ribbon
M Geyer - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,699
