跳转到主内容
Acer Aspire S3-391-6046 Battery Replacement
你所需要的
  1. Acer Aspire S3-391-6046 Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Place laptop upside down.
  2. Acer Aspire S3-391-6046 Battery Replacement: 步骤 2 中的图像 1,2 Acer Aspire S3-391-6046 Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the twelve 5mm screws with a Phillips #1 screwdriver.
  3. Acer Aspire S3-391-6046 Battery Replacement: 步骤 3 中的图像 1,1
    • Lift cover upwards away from you.
  4. Acer Aspire S3-391-6046 Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • With the Phillips #1 screwdriver, remove the two 5mm screws located on either side of the battery.
  5. Acer Aspire S3-391-6046 Battery Replacement: 步骤 5 中的图像 1,2 Acer Aspire S3-391-6046 Battery Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Unplug the three white plugs from their sockets using tweezers by pinching the plugs and pulling them outwards.
    • Pulling with too much force will damage the plugs.
  6. Acer Aspire S3-391-6046 Battery Replacement: 步骤 6 中的图像 1,2 Acer Aspire S3-391-6046 Battery Replacement: 步骤 6 中的图像 2,2
    • Pull upwards on the plugs located on top of your battery until they have completely come off.
  7. Acer Aspire S3-391-6046 Battery Replacement: 步骤 7 中的图像 1,2 Acer Aspire S3-391-6046 Battery Replacement: 步骤 7 中的图像 2,2
    • Remove the electrical tape holding down the battery by peeling it upwards.
    • Grab the battery from the bottom and slide it out towards the direction of the bottom of the battery.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 706
