跳转到主内容
Acer Aspire S3 MS2346 Keyboard Replacement
你所需要的
  1. Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: 步骤 1 中的图像 1,3 Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: 步骤 1 中的图像 2,3 Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: 步骤 2 中的图像 1,3 Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: 步骤 2 中的图像 2,3 Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: 步骤 2 中的图像 3,3
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Acer Aspire S3 MS2346 Keyboard Replacement: 步骤 3 中的图像 1,2 Acer Aspire S3 MS2346 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Acer Aspire S3 MS2346 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Gently remove the motherboard.
  5. Acer Aspire S3 MS2346 Keyboard Replacement, Speakers: 步骤 5 中的图像 1,2 Acer Aspire S3 MS2346 Keyboard Replacement, Speakers: 步骤 5 中的图像 2,2
    • Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
  6. Acer Aspire S3 MS2346 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
  7. Acer Aspire S3 MS2346 Keyboard Replacement, Battery: 步骤 7 中的图像 1,1
    • Gently lift the battery from the frame.
  8. Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: 步骤 8 中的图像 1,3 Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: 步骤 8 中的图像 2,3 Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: 步骤 8 中的图像 3,3
    • The 30 1mm PH000 screws holding the keyboard in place will be distributed all over the back.
    • You will need to gently pry up the black tape to expose the remaining screws.
  9. Acer Aspire S3 MS2346 Keyboard Replacement: 步骤 9 中的图像 1,1
    • Gently lift the board exposing the keyboard assembly.
结论
另外一个人完成了本指南。
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 21
总计 1,483
