跳转到主内容
Acer Aspire S3 MS2346 Display Assembly Replacement
你所需要的
  1. Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: 步骤 1 中的图像 1,3 Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: 步骤 1 中的图像 2,3 Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: 步骤 2 中的图像 1,3 Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: 步骤 2 中的图像 2,3 Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: 步骤 2 中的图像 3,3
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Acer Aspire S3 MS2346 Display Assembly Replacement: 步骤 3 中的图像 1,2 Acer Aspire S3 MS2346 Display Assembly Replacement: 步骤 3 中的图像 2,2
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Acer Aspire S3 MS2346 Display Assembly Replacement: 步骤 4 中的图像 1,1
    • Gently remove the motherboard.
  5. Acer Aspire S3 MS2346 Display Assembly Replacement, Display Assembly: 步骤 5 中的图像 1,2 Acer Aspire S3 MS2346 Display Assembly Replacement, Display Assembly: 步骤 5 中的图像 2,2
    • Unscrew the 10 5mm PH00 screws from the hinges attaching the display assembly to the base.
  6. Acer Aspire S3 MS2346 Display Assembly Replacement: 步骤 6 中的图像 1,1
    • Unlatch the screen from the frame
结论
3等其他人完成本指南。
团队
3条评论
Hey where can I find the screen for this model, cause currently my laptop screen backlight spoiled.
Harry joel - 回复
You can find this screen on 3rd party sites such as newegg and ebay.
Stacy Schauls -
Please arrange me a screen for this acer aspire S3 ms 2346
Amit Gangwar - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 17
总计 3,177
