跳转到主内容
Acer Aspire R7-572-6423 Battery Replacement
你所需要的
  1. Acer Aspire R7-572-6423 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the laptop and disconnect the power adapter before attempting this guide. Failure to do so can result in a shock hazard.
  2. Acer Aspire R7-572-6423 Battery Replacement: 步骤 2 中的图像 1,2 Acer Aspire R7-572-6423 Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the top and middle rubber feet under the laptop to reveal hidden screws.
  3. Acer Aspire R7-572-6423 Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the five 6 mm T9 screws.
    • Remove the eight 10 mm T9 screws.
  4. Acer Aspire R7-572-6423 Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the back cover.
  5. Acer Aspire R7-572-6423 Battery Replacement: 步骤 5 中的图像 1,1
    • Unplug the ribbon cable connecting the battery to the motherboard.
    • Be careful around the motherboard, as it is easily damaged.
  6. Acer Aspire R7-572-6423 Battery Replacement: 步骤 6 中的图像 1,1
    • Remove the three 4 mm Phillips #1 screws securing the battery.
  7. Acer Aspire R7-572-6423 Battery Replacement: 步骤 7 中的图像 1,2 Acer Aspire R7-572-6423 Battery Replacement: 步骤 7 中的图像 2,2
    • Pull open the clips on either side of the battery to free it from the case.
    • Remove the battery from the computer.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 17
总计 1,507
