跳转到主内容
Acer Aspire R7-371T-72CF Wifi Chip Replacement
你所需要的
  1. Acer Aspire R7-371T-72CF Wifi Chip Replacement, Wifi Chip: 步骤 1 中的图像 1,2 Acer Aspire R7-371T-72CF Wifi Chip Replacement, Wifi Chip: 步骤 1 中的图像 2,2
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF Wifi Chip Replacement: 步骤 2 中的图像 1,1
    • Using your prying tool, carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF Wifi Chip Replacement: 步骤 3 中的图像 1,3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: 步骤 3 中的图像 2,3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: 步骤 3 中的图像 3,3
    • Locate the wifi chip, as shown to the left.
    • The chip can by identified by the white and black wires connected to it, as well as a single screw holding it in place.
  4. Acer Aspire R7-371T-72CF Wifi Chip Replacement: 步骤 4 中的图像 1,3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: 步骤 4 中的图像 2,3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: 步骤 4 中的图像 3,3
    • Locate the 2 antenna wires connected to the chip.
    • One is black, and the other is white.
    • Use a spudger or plastic opening tool to carefully disconnect the wires from the chip by prying upwards.
    • The connectors 'click' into place, like a button.
  5. Acer Aspire R7-371T-72CF Wifi Chip Replacement: 步骤 5 中的图像 1,2 Acer Aspire R7-371T-72CF Wifi Chip Replacement: 步骤 5 中的图像 2,2
    • Remove the Phillips #00 6mm securing screw using your screwdriver.
  6. Acer Aspire R7-371T-72CF Wifi Chip Replacement: 步骤 6 中的图像 1,1
    • Remove the chip by pulling towards the edge of the computer.
结论
2等其他人完成本指南。
Dylan Meintser
于09/27/17注册
476 声望
创作了4篇指南
团队
Cal Poly, Team S8-G5, Banghart Fall 2017 Cal Poly, Team S8-G5, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S8G5
5 名成员
创作了5篇指南
一条评论
Any idea on screen replacement for this particular model? I’ve been searching for a video all week. Please help me out if possible
Hasan Mahmood - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 543
