跳转到主内容
Acer Aspire R7-371T-72CF Power Port Replacement
你所需要的
  1. Acer Aspire R7-371T-72CF Power Port Replacement, Power Port: 步骤 1 中的图像 1,2 Acer Aspire R7-371T-72CF Power Port Replacement, Power Port: 步骤 1 中的图像 2,2
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF Power Port Replacement: 步骤 2 中的图像 1,1
    • Using your prying tool, carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF Power Port Replacement: 步骤 3 中的图像 1,3 Acer Aspire R7-371T-72CF Power Port Replacement: 步骤 3 中的图像 2,3 Acer Aspire R7-371T-72CF Power Port Replacement: 步骤 3 中的图像 3,3
    • Locate the power connector, as shown on the left.
    • The power connector will be in the same location as where you normally plug the charger into the laptop to charge your device.
  4. Acer Aspire R7-371T-72CF Power Port Replacement: 步骤 4 中的图像 1,3 Acer Aspire R7-371T-72CF Power Port Replacement: 步骤 4 中的图像 2,3 Acer Aspire R7-371T-72CF Power Port Replacement: 步骤 4 中的图像 3,3
    • Disconnect the wiring from the motherboard, and pull out the rest of the wire carefully.
    • Make sure the wire is not caught on anything before pulling.
  5. Acer Aspire R7-371T-72CF Power Port Replacement: 步骤 5 中的图像 1,1
    • Pull out the power connector by pulling upwards on the wires.
    • This may require a small amount of force, but should pop out with some pressure.
结论
另外一个人完成了本指南。
Ethan Frey
于09/27/17注册
117 声望
撰写一个指南
团队
Cal Poly, Team S8-G5, Banghart Fall 2017 Cal Poly, Team S8-G5, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S8G5
5 名成员
创作了5篇指南
4条评论
What’s the part number for the power jack cable, and who sells it?
AcerFan - 回复
50.mqpn7.001 (SIQDD0ZS8AD001)
I found it here: https://www.itpartsource.com/50MQPN7001-...
Jorge Prado - 回复
What model is this? Is this the older (~2015) model with the small cylindrical charging port?
Sarah - 回复
The associated part id numbers for the Acer R7-371t 45W DC Jack Cable are:
50.MQPN7.001
SIQDD0ZS8AD001
Unfortunately, I have found this part impossible to find in stock at any source.
rosemank - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 1,695
