跳转到主内容
Acer Aspire R7 Battery Replacement
你所需要的
  1. Acer Aspire R7 Battery Replacement, Cover: 步骤 1 中的图像 1,1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 Battery Replacement: 步骤 2 中的图像 1,3 Acer Aspire R7 Battery Replacement: 步骤 2 中的图像 2,3 Acer Aspire R7 Battery Replacement: 步骤 2 中的图像 3,3
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 Battery Replacement: 步骤 3 中的图像 1,1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Battery Replacement, Battery: 步骤 4 中的图像 1,2 Acer Aspire R7 Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Locate the battery ribbon connector
    • Remove the ribbon cable attaching the battery to the motherboard by carefully pulling it outwards
    • When using the spudger be careful around the motherboard as it can easily be damaged
  5. Acer Aspire R7 Battery Replacement: 步骤 5 中的图像 1,3 Acer Aspire R7 Battery Replacement: 步骤 5 中的图像 2,3 Acer Aspire R7 Battery Replacement: 步骤 5 中的图像 3,3
    • Remove the three 4.5mm #00 Phillips screws attaching the battery to the motherboard
    • Push the 4 retaining clips away from the battery
    • Carefully lift the battery from the motherboard
结论
12等其他人完成本指南。
F Fernandez
于01/13/15注册
435 声望
创作了2篇指南
团队
USF Tampa, Team 3-4, Hickman Winter 2015 USF Tampa, Team 3-4, Hickman Winter 2015 的会员
USFT-HICKMAN-W15S3G4
4 名成员
创作了7篇指南
6条评论
What is the battery reference for replacement ?
skalpinou - 回复
which battery model do I purchase for replacing on an Acer Aspire R?
Eddie - 回复
hey how do you want då sel it for
Alex santos - 回复
super tuto
Thanks
P.S : A have add a short comment on step 2.
Bests regards
Anthymoine - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 37
总计 41,249
