跳转到主内容
Acer Aspire R7 AC Socket Replacement
你所需要的
  1. Acer Aspire R7 AC Socket Replacement, Cover: 步骤 1 中的图像 1,1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 AC Socket Replacement: 步骤 2 中的图像 1,3 Acer Aspire R7 AC Socket Replacement: 步骤 2 中的图像 2,3 Acer Aspire R7 AC Socket Replacement: 步骤 2 中的图像 3,3
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 AC Socket Replacement: 步骤 3 中的图像 1,1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 AC Socket Replacement, AC Socket: 步骤 4 中的图像 1,3 Acer Aspire R7 AC Socket Replacement, AC Socket: 步骤 4 中的图像 2,3 Acer Aspire R7 AC Socket Replacement, AC Socket: 步骤 4 中的图像 3,3
    • Locate the AC Socket ribbon connector
    • Loosen the ribbon connector using the plastic opening tool
    • Pull the ribbon connector away from the motherboard
  5. Acer Aspire R7 AC Socket Replacement: 步骤 5 中的图像 1,2 Acer Aspire R7 AC Socket Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to pry up on the yellow tabs holding the Socket in place
    • There is two sided tape holding this component to the case
    • Once the tape on the Socket is loose, pull up and away from the case to remove it.
结论
另外一个人完成了本指南。
Andrew Rodiek
于01/13/15注册
601 声望
创作了4篇指南
团队
USF Tampa, Team 3-4, Hickman Winter 2015 USF Tampa, Team 3-4, Hickman Winter 2015 的会员
USFT-HICKMAN-W15S3G4
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 1,410
