跳转到主内容
Acer Aspire R5-571T-59DC RAM Replacement
你所需要的
  1. Acer Aspire R5-571T-59DC RAM Replacement, Back Cover Panel: 步骤 1 中的图像 1,2 Acer Aspire R5-571T-59DC RAM Replacement, Back Cover Panel: 步骤 1 中的图像 2,2
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC RAM Replacement, RAM: 步骤 2 中的图像 1,1
    • Lift up the protective covering away from the RAM using tweezers, or your fingers.
  3. Acer Aspire R5-571T-59DC RAM Replacement: 步骤 3 中的图像 1,3 Acer Aspire R5-571T-59DC RAM Replacement: 步骤 3 中的图像 2,3 Acer Aspire R5-571T-59DC RAM Replacement: 步骤 3 中的图像 3,3
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
    • Lift the RAM module to an angle of about 30 degrees and slide it out.
结论
2等其他人完成本指南。
Kelly Johnston
于01/25/18注册
600 声望
创作了4篇指南
团队
USF Tampa, Team S20-G2, Passmore Spring 2018 USF Tampa, Team S20-G2, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S20G2
3 名成员
创作了7篇指南
一条评论
How many slots for RAM does this laptop have? Is there a soldered stick in one of the slots? Thanks!
Alberto Einsteino - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 956
