简介
This guide shows the reader how to remove the back cover from their Acer Aspire R15 and replace the battery.
It may be necessary to replace this component if the laptop won't stay on while turned in, or is unable to hold a charge.
Before starting this guide, it is important to ensure the device is unplugged and powered off in order to avoid doing serious damage to the electronics.
你所需要的
Disconnect all power from the laptop and turn over so the bottom is facing you.
Remove the twelve 07.mm Phillips #0 screws from the back cover.
Work a plastic opening tool underneath and around the perimeter of the bottom cover.
Once unclipped, remove the bottom cover.
Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
Lift the battery out of the case.
另外一个人完成了本指南。
一条评论
This seems to be the correct battery for the replacement, judging by the above photos, the AC14B3K
Acer AC14B3K, AC14B8J, and AC14B8K Laptop Battery
I plan to try this repair myself soon.
