跳转到主内容
Acer Aspire R5-471T-52EE Screen Replacement
你所需要的
  1. Acer Aspire R5-471T-52EE Screen Replacement, Back Cover: 步骤 1 中的图像 1,2 Acer Aspire R5-471T-52EE Screen Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Screen Replacement: 步骤 2 中的图像 1,1
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
  3. Acer Aspire R5-471T-52EE Screen Replacement, Screen: 步骤 3 中的图像 1,1
    • Disconnect the three wires from the motherboard that connect to the screen.
    • Be very gentle when removing these wires as the connections with the motherboard are delicate.
  4. Acer Aspire R5-471T-52EE Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the eight 3mm screws on the hinges using the Phillips #1 screwdriver.
    • Now that the hinges have been unfastened, carefully separate the screen and screen casing from the other half of the computer.
  5. Acer Aspire R5-471T-52EE Screen Replacement: 步骤 5 中的图像 1,2 Acer Aspire R5-471T-52EE Screen Replacement: 步骤 5 中的图像 2,2
    • Using a spudger or an opening pick, pop open the case holding the screen. Follow the line where the two pieces of the case meet all around the screen.
    • Remove the display assembly from the device.
结论
To install the screen and reassemble your device, follow these instructions in reverse order.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 355
