跳转到主内容
Acer Aspire R5-471T-52EE Fan Replacement
你所需要的
  1. Acer Aspire R5-471T-52EE Fan Replacement, Back Cover: 步骤 1 中的图像 1,2 Acer Aspire R5-471T-52EE Fan Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Fan Replacement: 步骤 2 中的图像 1,1
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
  3. Acer Aspire R5-471T-52EE Fan Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Remove seven 3 mm screws using the Phillips #00 screwdriver.
  4. Acer Aspire R5-471T-52EE Fan Replacement: 步骤 4 中的图像 1,1
    • Once the screws are removed, disconnect seven plugs from the motherboard.
    • Keep in mind that a majority of these wires are extremely thin and fragile. Disconnect them with light force and care.
  5. Acer Aspire R5-471T-52EE Fan Replacement: 步骤 5 中的图像 1,1
    • Flip up the small black portion the connectors are connected to and disconnect them from the motherboard.
    • Grab the yellow piece of tape to easily remove the connection from the motherboard with nothing more than some gentle force.
    • Remove the large black ribbon wire by gently pulling on the white tab towards yourself.
    • Remove the large white ribbon wire by pulling up on the small black tab.
  6. Acer Aspire R5-471T-52EE Fan Replacement: 步骤 6 中的图像 1,1
    • Remove the four remaining screws located on the fan using the Phillips #00 screwdriver.
  7. Acer Aspire R5-471T-52EE Fan Replacement, Fan: 步骤 7 中的图像 1,2 Acer Aspire R5-471T-52EE Fan Replacement, Fan: 步骤 7 中的图像 2,2
    • Flip the motherboard over so that the silver and copper covers are exposed.
    • Use the opening tool to gently lift the copper cover off the board by sliding the tool underneath the edge.
  8. Acer Aspire R5-471T-52EE Fan Replacement: 步骤 8 中的图像 1,1
    • Unplug the two power cables for the fans from the motherboard.
    • Remove the four mounting screws from the motherboard using a Phillips #00 screwdriver.
  9. Acer Aspire R5-471T-52EE Fan Replacement: 步骤 9 中的图像 1,1
    • Gently remove the fans from the motherboard.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 302
