跳转到主内容
Acer Aspire R5-471T-52EE Battery Replacement
你所需要的
  1. Acer Aspire R5-471T-52EE Battery Replacement, Back Cover: 步骤 1 中的图像 1,2 Acer Aspire R5-471T-52EE Battery Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Battery Replacement: 步骤 2 中的图像 1,1
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
  3. Acer Aspire R5-471T-52EE Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Using your fingers, gently disconnect the battery plug from the motherboard.
    • Remove the two screws using a Phillips #00 screwdriver.
    • Remove the battery from the device.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 1,023
