跳转到主内容
Acer Aspire R11 R3-131T-C1Z5 Battery Replacement
你所需要的
  1. Acer Aspire R11 R3-131T-C1Z5 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Acer Aspire R11 R3-131T-C1Z5 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the laptop on to its front, so that the back is facing up
    • Unscrew the twelve 19.05 mm PH#0 screws.
  2. Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: 步骤 2 中的图像 1,2 Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: 步骤 2 中的图像 2,2
    • At the left front corner of the laptop, under the intel sticker, press the sharp end of a metal spudger between the keyboard and the back cover to pry it apart.
  3. Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Connect the clip of an anti-static wrist strap to any piece of metal on the computer.
    • It is important to ground yourself to avoid static.
  4. Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: 步骤 4 中的图像 1,2 Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: 步骤 4 中的图像 2,2
    • Locate the large black rectangle at the bottom . This is your battery.
    • If you see that your battery is oozing or bulging, step away from the device.
    • Remove the black electric tape that is on the rainbow colored cable at the top of the battery.
    • Gently pull on the cable to disconnect.
  5. Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: 步骤 5 中的图像 1,3 Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: 步骤 5 中的图像 2,3 Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: 步骤 5 中的图像 3,3
    • Remove the two 12.7 mm PH#0 screws. One of these screws is located on the top of the left side of the battery and the other is located in the top of the right side of the battery.
    • Remove the battery
结论
3等其他人完成本指南。
2条评论
Nicely done manual, however share your thoughts, my ‘puter showed critical battery, I replaced an original AC14B3K with a Flyten AC14B8K battery and I have -0- lights/power. What are your thoughts?
S M Sendele - 回复
Concise, easy to follow instructions! Hint: make sure you remove ALL of the screws from the back, or it won’t come off
Dierdre - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 56
总计 6,785
