跳转到主内容
Acer Aspire R R5-471T-51UN Keyboard Replacement
你所需要的
  1. Acer Aspire R R5-471T-51UN Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Acer Aspire R R5-471T-51UN Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Acer Aspire R R5-471T-51UN Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip your laptop over so the bottom is facing you.
    • Remove the twelve 5 mm screws with a Phillips #0 screwdriver.
  2. Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 2 中的图像 1,3 Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 2 中的图像 2,3 Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 2 中的图像 3,3
    • Insert the Jimmy between the back cover of the laptop and the base of the laptop and then slowly use the Jimmy to pry off the back cover of the laptop.
  3. Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 3 中的图像 1,2 Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 3 中的图像 2,2
    • Use your Phillips #0 screwdriver to remove the two 3mm screws on the battery.
  4. Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 4 中的图像 1,3 Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 4 中的图像 2,3 Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 4 中的图像 3,3
    • Gently and cautiously pinch the white ends of the battery connector cable and slowly pull it from the motherboard.
  5. Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 5 中的图像 1,2 Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 5 中的图像 2,2
    • Gently lift the battery out of the laptop.
    • Be cautious with the lithium ion battery as you remove it.
  6. Acer Aspire R R5-471T-51UN Keyboard Replacement, Keyboard: 步骤 6 中的图像 1,3 Acer Aspire R R5-471T-51UN Keyboard Replacement, Keyboard: 步骤 6 中的图像 2,3 Acer Aspire R R5-471T-51UN Keyboard Replacement, Keyboard: 步骤 6 中的图像 3,3
    • Use the spudger to flip up the locking tabs on each of the four ZIF cable connectors.
    • Remove each of the ribbon cables from their connectors.
  7. Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 7 中的图像 1,3 Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 7 中的图像 2,3 Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 7 中的图像 3,3
    • Using the Phillips #0 screwdriver, remove the eight 3 mm screws holding in the motherboard and the three 3 mm screws holding down the fan.
  8. Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 8 中的图像 1,3 Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 8 中的图像 2,3 Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 8 中的图像 3,3
    • Remove the motherboard and the fan by gently pulling them out of the assembly.
    • Using the Phillips #0 screwdriver, remove the three 3 mm screws holding down the daughterboard and gently pull it up and out of the assembly.
  9. Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 9 中的图像 1,3 Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 9 中的图像 2,3 Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 9 中的图像 3,3
    • Using the Phillips #0 screwdriver, remove the eight 5 mm screws from the display brackets on either side.
  10. Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 10 中的图像 1,2 Acer Aspire R R5-471T-51UN Keyboard Replacement: 步骤 10 中的图像 2,2
    • Remove the keyboard assembly by gently pulling it up.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 512
