跳转到主内容
Acer Aspire R R5-471T-51UN Display Assembly Replacement
你所需要的
  1. Acer Aspire R R5-471T-51UN Display Assembly Replacement, Battery: 步骤 1 中的图像 1,3 Acer Aspire R R5-471T-51UN Display Assembly Replacement, Battery: 步骤 1 中的图像 2,3 Acer Aspire R R5-471T-51UN Display Assembly Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip your laptop over so the bottom is facing you.
    • Remove the twelve 5 mm screws with a Phillips #0 screwdriver.
  2. Acer Aspire R R5-471T-51UN Display Assembly Replacement: 步骤 2 中的图像 1,3 Acer Aspire R R5-471T-51UN Display Assembly Replacement: 步骤 2 中的图像 2,3 Acer Aspire R R5-471T-51UN Display Assembly Replacement: 步骤 2 中的图像 3,3
    • Insert the Jimmy between the back cover of the laptop and the base of the laptop and then slowly use the Jimmy to pry off the back cover of the laptop.
  3. Acer Aspire R R5-471T-51UN Display Assembly Replacement: 步骤 3 中的图像 1,2 Acer Aspire R R5-471T-51UN Display Assembly Replacement: 步骤 3 中的图像 2,2
    • Use your Phillips #0 screwdriver to remove the two 3mm screws on the battery.
  4. Acer Aspire R R5-471T-51UN Display Assembly Replacement: 步骤 4 中的图像 1,3 Acer Aspire R R5-471T-51UN Display Assembly Replacement: 步骤 4 中的图像 2,3 Acer Aspire R R5-471T-51UN Display Assembly Replacement: 步骤 4 中的图像 3,3
    • Gently and cautiously pinch the white ends of the battery connector cable and slowly pull it from the motherboard.
  5. Acer Aspire R R5-471T-51UN Display Assembly Replacement: 步骤 5 中的图像 1,2 Acer Aspire R R5-471T-51UN Display Assembly Replacement: 步骤 5 中的图像 2,2
    • Gently lift the battery out of the laptop.
    • Be cautious with the lithium ion battery as you remove it.
  6. Acer Aspire R R5-471T-51UN Display Assembly Replacement, Display Assembly: 步骤 6 中的图像 1,3 Acer Aspire R R5-471T-51UN Display Assembly Replacement, Display Assembly: 步骤 6 中的图像 2,3 Acer Aspire R R5-471T-51UN Display Assembly Replacement, Display Assembly: 步骤 6 中的图像 3,3
    • Using the Phillips #0 screwdriver, unscrew the eight 5mm screws securing the screen brackets in place.
  7. Acer Aspire R R5-471T-51UN Display Assembly Replacement: 步骤 7 中的图像 1,3 Acer Aspire R R5-471T-51UN Display Assembly Replacement: 步骤 7 中的图像 2,3 Acer Aspire R R5-471T-51UN Display Assembly Replacement: 步骤 7 中的图像 3,3
    • Using the spudger, push up the locking tab of the ZIF interconnect cable so that the ribbon cable pops out.
  8. Acer Aspire R R5-471T-51UN Display Assembly Replacement: 步骤 8 中的图像 1,2 Acer Aspire R R5-471T-51UN Display Assembly Replacement: 步骤 8 中的图像 2,2
    • Disconnect the coaxial cables on the Wi-Fi card by pinching the ends of the cables and slowly pulling them out.
    • Using the Phillips #0 screwdriver, unscrew the 3mm screw holding the Wi-Fi card in place and take out the card.
    • Pry up the display brackets so they are clear of the motherboard and case.
  9. Acer Aspire R R5-471T-51UN Display Assembly Replacement: 步骤 9 中的图像 1,3 Acer Aspire R R5-471T-51UN Display Assembly Replacement: 步骤 9 中的图像 2,3 Acer Aspire R R5-471T-51UN Display Assembly Replacement: 步骤 9 中的图像 3,3
    • Gently pull off the display assembly so that it comes apart from the rest of the laptop.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 338
