跳转到主内容
Acer Aspire R R5-471T-51UN Battery Replacement
你所需要的
  1. Acer Aspire R R5-471T-51UN Battery Replacement, Battery: 步骤 1 中的图像 1,3 Acer Aspire R R5-471T-51UN Battery Replacement, Battery: 步骤 1 中的图像 2,3 Acer Aspire R R5-471T-51UN Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip your laptop over so the bottom is facing you.
    • Remove the twelve 5 mm screws with a Phillips #0 screwdriver.
  2. Acer Aspire R R5-471T-51UN Battery Replacement: 步骤 2 中的图像 1,3 Acer Aspire R R5-471T-51UN Battery Replacement: 步骤 2 中的图像 2,3 Acer Aspire R R5-471T-51UN Battery Replacement: 步骤 2 中的图像 3,3
    • Insert the Jimmy between the back cover of the laptop and the base of the laptop and then slowly use the Jimmy to pry off the back cover of the laptop.
  3. Acer Aspire R R5-471T-51UN Battery Replacement: 步骤 3 中的图像 1,2 Acer Aspire R R5-471T-51UN Battery Replacement: 步骤 3 中的图像 2,2
    • Use your Phillips #0 screwdriver to remove the two 3mm screws on the battery.
  4. Acer Aspire R R5-471T-51UN Battery Replacement: 步骤 4 中的图像 1,3 Acer Aspire R R5-471T-51UN Battery Replacement: 步骤 4 中的图像 2,3 Acer Aspire R R5-471T-51UN Battery Replacement: 步骤 4 中的图像 3,3
    • Gently and cautiously pinch the white ends of the battery connector cable and slowly pull it from the motherboard.
  5. Acer Aspire R R5-471T-51UN Battery Replacement: 步骤 5 中的图像 1,2 Acer Aspire R R5-471T-51UN Battery Replacement: 步骤 5 中的图像 2,2
    • Gently lift the battery out of the laptop.
    • Be cautious with the lithium ion battery as you remove it.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 952
