跳转到主内容
Acer Aspire One P1VE6 Hard Drive Replacement
你所需要的
  1. Acer Aspire One P1VE6 Hard Drive Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Close the netbook and turn it over so the back panel faces you.
  2. Acer Aspire One P1VE6 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Locate the 4 mm Phillips #1 screw at the bottom of the back panel. Using the Phillips head screwdriver, remove the screw. Place the screw somewhere it will not be lost. Then remove the back panel by gently sliding it towards the front.
  3. Acer Aspire One P1VE6 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • After removing the back panel, locate the hard drive.
  4. Acer Aspire One P1VE6 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Carefully lift up the hard drive.
  5. Acer Aspire One P1VE6 Hard Drive Replacement: 步骤 5 中的图像 1,2 Acer Aspire One P1VE6 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Locate the two 4 mm Philips #1 screws holding the hard drive into its bracket.
    • Remove the two screws and place them somewhere they will not be lost.
  6. Acer Aspire One P1VE6 Hard Drive Replacement: 步骤 6 中的图像 1,2 Acer Aspire One P1VE6 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Unplug the hard drive from the bracket.
结论
2条评论
tiene 4 ram hasta cuanto soporta gracias...
elteto77 - 回复
Was reviewing this to see if it was possible to reattach the drive connector if removed. (dealing with this in this model of laptop)
Shirley Hicks - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 23
总计 2,776
