跳转到主内容
Acer Aspire One D257 Keyboard Replacement
你所需要的
  1. Acer Aspire One D257 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Put the netbook, so the back side is upwards.
  2. Acer Aspire One D257 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Push the right lock to the right so the red filed is visible on the left.
  3. Acer Aspire One D257 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Now move the left lock which is spring loaded to the leftand keep it there. Then with the other hand remove the battery by pulling down.
    • When reassembeling the new battery push it up into the netbook and do lock the right by moving it to the left so the red field disappears.
  4. Acer Aspire One D257 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,2 Acer Aspire One D257 Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Open the lid othe the netbook. Use the Jimmy from the upper left corner of the keyboard. Put it between the keyboard and th casing and move it to the right. It might help to use a metal spudger to push in the pins holding the keyboard in place.
    • Then move down along the sides where there is one pin on each side. After that twist the keyboard towards you.
    There are little spring loaded lock bolts. Push them away from the keyboard.
    darsie - 回复
  5. Acer Aspire One D257 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Now open the brown connector so the flat cable is loose. Then you can remove the keyboard.
    Lets see, the most delicate operation of all- flexible flat cable removal- and you say open it till loose. How ? Is the type of retainer that moves backwards, flips up or has side clips. Guess wrong and you are buying a new motherboard. Of course that could be the point of the ommission
    John Dawson - 回复
    The hinge lock flips up.
    darsie - 回复
结论
5等其他人完成本指南。
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Claes
于02/01/16注册
3,400 声望
创作了6篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,519篇指南
一条评论
I lost the flat retaining of the keyboard, what can I use?
ciccio - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,935
