当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Using a spudger remove the two screw covers on the front of the computer.
Remove the two 1.2 mm Phillips #1 screws that were located under the screw covers.
Using a spudger for assistance remove the front panel of the screen.
It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
Remove the eight 1.2 mm Phillips #1 screws holding on the screen.
There are wires connected to the screen unit. Make sure you do not attempt to pull off the screen just yet!
Carefully remove the display ribbon cable from the connector.
取消:我没有完成这个指南。
3等其他人完成本指南。
与1其他贡献者
于03/19/16注册
1,248 声望
创作了5篇指南
徽章: 10
+ 7更多徽章
UMASSD-BHUSAL-S16S16G8
2 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 32
总计 2,112
