跳转到主内容
Acer Aspire One D255E RAM Replacement
你所需要的
  1. Acer Aspire One D255E RAM Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Start by removing the battery found on the back of the device.
    • The battery must be removed in order to ensure the device does not have power! Make sure you do not skip this step!
  2. Acer Aspire One D255E RAM Replacement: 步骤 2 中的图像 1,2 Acer Aspire One D255E RAM Replacement: 步骤 2 中的图像 2,2
    • Using plastic opening tools press down the 6 clips located around the keyboard.
  3. Acer Aspire One D255E RAM Replacement: 步骤 3 中的图像 1,3 Acer Aspire One D255E RAM Replacement: 步骤 3 中的图像 2,3 Acer Aspire One D255E RAM Replacement: 步骤 3 中的图像 3,3
    • Using a plastic opening tool or spudger move the keyboard out of position.
    • There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable.
    • If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E RAM Replacement: 步骤 4 中的图像 1,1
    • Using a spudger gently push the tab on the port forward then pull out the cable.
    • Be careful to do so as gently as possible. You do not want to damage the port.
  5. Acer Aspire One D255E RAM Replacement, Back Panel: 步骤 5 中的图像 1,2 Acer Aspire One D255E RAM Replacement, Back Panel: 步骤 5 中的图像 2,2
    • Unscrew seven 1.2 mm Phillips #1 screws from the back of the device
  6. Acer Aspire One D255E RAM Replacement: 步骤 6 中的图像 1,2 Acer Aspire One D255E RAM Replacement: 步骤 6 中的图像 2,2
    • Unscrew eight more 1.2 mm Phillips #1 screws from the front of the computer.
  7. Acer Aspire One D255E RAM Replacement: 步骤 7 中的图像 1,3 Acer Aspire One D255E RAM Replacement: 步骤 7 中的图像 2,3 Acer Aspire One D255E RAM Replacement: 步骤 7 中的图像 3,3
    • Using a spudger carefully push though the hole to dislodge the panel on the back of the device then remove the panel by hand.
    • It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  8. Acer Aspire One D255E RAM Replacement, RAM: 步骤 8 中的图像 1,3 Acer Aspire One D255E RAM Replacement, RAM: 步骤 8 中的图像 2,3 Acer Aspire One D255E RAM Replacement, RAM: 步骤 8 中的图像 3,3
    • Using your hands pull apart the two clips holding the RAM in then pull out the RAM.
    • It uses (DDR3) 204pin PC3-10600 1333MHz DDR3 SO-DIMM Memory Modules
结论
7等其他人完成本指南。
Brian
于03/19/16注册
1,248 声望
创作了5篇指南
团队
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 UMass Dartmouth, Team 16-8, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S16G8
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 30
总计 4,523
