跳转到主内容
Acer Aspire One D255-1625 Keyboard Replacement
你所需要的
  1. Acer Aspire One D255-1625 Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Acer Aspire One D255-1625 Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Acer Aspire One D255-1625 Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Before you replace the battery, ensure that the device is unplugged and powered off.
    • Pull the upper left switch on the back of the laptop to the left into the unlock position.
    • Pull the upper right switch to the left and hold it in place.
  2. Acer Aspire One D255-1625 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Pull the battery straight out.
    • To properly dispose of battery, locate your nearest recycling plant to dispose of it there.
  3. Acer Aspire One D255-1625 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,2 Acer Aspire One D255-1625 Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,2
    • Use iFixit's Jimmy tool and press it into the small tabs at the top of the keyboard and lift up.
    • Do this for all five tabs at the top of the keyboard.
  4. Acer Aspire One D255-1625 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Slide the Jimmy tool along the top of the keyboard once all tabs have been pressed in.
  5. Acer Aspire One D255-1625 Keyboard Replacement: 步骤 5 中的图像 1,3 Acer Aspire One D255-1625 Keyboard Replacement: 步骤 5 中的图像 2,3 Acer Aspire One D255-1625 Keyboard Replacement: 步骤 5 中的图像 3,3
    • Flip the keyboard forward to expose its connection.
    • Slide the small brown tab out to disconnect the keyboard.
    • Lift the keyboard away from the laptop.
    • If you see that the keyboard is not connected upon flipping, reconnect it and see if it works. If not, continue to replace the keyboard.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 17
总计 302
