跳转到主内容
Acer Aspire One D255-1625 Fan Replacement
你所需要的
  1. Acer Aspire One D255-1625 Fan Replacement, Battery: 步骤 1 中的图像 1,3 Acer Aspire One D255-1625 Fan Replacement, Battery: 步骤 1 中的图像 2,3 Acer Aspire One D255-1625 Fan Replacement, Battery: 步骤 1 中的图像 3,3
    • Before you replace the battery, ensure that the device is unplugged and powered off.
    • Pull the upper left switch on the back of the laptop to the left into the unlock position.
    • Pull the upper right switch to the left and hold it in place.
  2. Acer Aspire One D255-1625 Fan Replacement: 步骤 2 中的图像 1,1
    • Pull the battery straight out.
    • To properly dispose of battery, locate your nearest recycling plant to dispose of it there.
  3. Acer Aspire One D255-1625 Fan Replacement, Fan: 步骤 3 中的图像 1,2 Acer Aspire One D255-1625 Fan Replacement, Fan: 步骤 3 中的图像 2,2
    • Use iFixit’s Jimmy tool to remove bottom panel of device.
    • Wedge the tool into the top middle of the panel until the back gently pops off.
  4. Acer Aspire One D255-1625 Fan Replacement: 步骤 4 中的图像 1,3 Acer Aspire One D255-1625 Fan Replacement: 步骤 4 中的图像 2,3 Acer Aspire One D255-1625 Fan Replacement: 步骤 4 中的图像 3,3
    • Use the tweezers to disconnect the fan's wires from laptop.
    • Use the Phillips #1 screwdriver to remove the three 4mm screws that hold the fan in place.
    • The 3rd screw on the bottom right is extremely difficult to remove as it requires you to bend the motherboard slightly in order to reach it.
  5. Acer Aspire One D255-1625 Fan Replacement: 步骤 5 中的图像 1,1
    • Pull the fan out of the housing unit.
    • You may need to use the iFixit Jimmy tool to help pull the fan out.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 378
