跳转到主内容
Acer Aspire One D250-1151 Hard drive Replacement
你所需要的
  1. Acer Aspire One D250-1151 Hard drive Replacement, Hard drive: 步骤 1 中的图像 1,1
    • Place the computer face down on a flat surface.
  2. Acer Aspire One D250-1151 Hard drive Replacement: 步骤 2 中的图像 1,1
    • Unscrew the Largest panel using a Philips PH1 screwdriver in a counterclockwise motion.
  3. Acer Aspire One D250-1151 Hard drive Replacement: 步骤 3 中的图像 1,1
    • Lift the panel with your finger to reveal the hard drive.
    After Step 3, you must remove the single black screw to release the aluminum drive tray, then proceed with Step 4.
    bmcd - 回复
  4. Acer Aspire One D250-1151 Hard drive Replacement: 步骤 4 中的图像 1,1
    • Slide the hard drive towards the battery until it is no longer connected.
  5. Acer Aspire One D250-1151 Hard drive Replacement: 步骤 5 中的图像 1,1
    • Lift the hard drive out of the compartment.
    After you remove the drive from the compartment, you must remove the four (4) screws on the side of the aluminum drive tray to remove the drive.
    bmcd - 回复
结论
2等其他人完成本指南。
Donny McKay
于11/03/16注册
494 声望
创作了4篇指南
团队
Baylor, Team 5-11, Williams Fall 2016 Baylor, Team 5-11, Williams Fall 2016 的会员
BU-WILLIAMS-F16S5G11
3 名成员
创作了14篇指南
一条评论
Easier than trying to reformat it on WindowsXP
waltcs1 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 1,298
