跳转到主内容
Acer Aspire One D250-1151 Battery Replacement
  1. Acer Aspire One D250-1151 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the computer is unplugged, and turned off completely
    • Place the computer on a flat surface with the bottom facing you.
  2. Acer Aspire One D250-1151 Battery Replacement: 步骤 2 中的图像 1,1
    • Place a finger on the small tab on the left with the lock and unlock symbols.
    • Slide this tab to the unlock position.
    • If done correctly, you should see an orange marker.
  3. Acer Aspire One D250-1151 Battery Replacement: 步骤 3 中的图像 1,1
    • Place a finger on the tab in the upper right corner.
    • Slide this tab to the right and hold it in that position.
  4. Acer Aspire One D250-1151 Battery Replacement: 步骤 4 中的图像 1,1
    • Place your finger on the three lines in the middle of the battery while holding the tab on the right.
  5. Acer Aspire One D250-1151 Battery Replacement: 步骤 5 中的图像 1,1
    • Push forward on the battery lines while holding the tab on the right.
结论
Evan Edmunds
于10/31/16注册
237 声望
创作了2篇指南
团队
Baylor, Team 5-11, Williams Fall 2016 Baylor, Team 5-11, Williams Fall 2016 的会员
BU-WILLIAMS-F16S5G11
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 1,314
