跳转到主内容
Acer Aspire One Cloudbook AO1-132-C3T3 Speakers Replacement
你所需要的
  1. Acer Aspire One Cloudbook AO1-132-C3T3 Speakers Replacement, Speakers: 步骤 1 中的图像 1,1
    • Remove eleven 4 mm Phillips #1 screws.
    • Gently remove the back lid.
  2. Acer Aspire One Cloudbook AO1-132-C3T3 Speakers Replacement: 步骤 2 中的图像 1,1
    • Once the panel is removed, you will see two speakers that is attached to the motherboard by a black cord.
    • Pull the cord gently to remove, you may have to wiggle the cord if it does not come out smoothly.
    • Repeat the process to remove the other cord.
  3. Acer Aspire One Cloudbook AO1-132-C3T3 Speakers Replacement: 步骤 3 中的图像 1,1
    • Pull upwards to remove the speaker.
    • Repeat the process to remove the second speaker.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 132
