跳转到主内容
Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement
你所需要的
  1. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove eleven 4 mm Phillips #1 screws.
    • Pull the backplate off using your fingers.
  2. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 步骤 2 中的图像 1,2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Pull the rainbow cord out of the motherboard using the tabs on the sides.
  3. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 步骤 3 中的图像 1,2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove three 3 mm Phillips #1 screws holding down the battery.
    • Lift the top edge of the battery and pull back towards the hinges to remove the battery.
  4. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Remove two 4 mm screws holding down the metal plate using a Phillips #1 screwdriver.
    • Remove the plate using your fingers.
    • Remove four 5 mm screws holding the motherboard in place using a Phillips #1 screwdriver.
  5. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Pull the yellow cord out from the motherboard using the sticker.
  6. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 步骤 6 中的图像 1,2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Pull both small blue ribbon cords out of the motherboard using the stickers.
  7. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Gently pull the black cord out from the motherboard.
  8. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Pull the top cord out of the motherboard using the sticker.
  9. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Gently pull the motherboard away from the small square chip to its left.
结论
另外一个人完成了本指南。
一条评论
Hello, can you please advise on how to replace the ram on this laptop
BenfromEssex - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 1,075
